I had to get my car fixed after an accident...since then the windshield washer fluid no longers comes out...and yes there is fluid in there...so I'm assuming that it's just not connected right or something...does anyone know where to check it or where the pump is located?
The pump is in the bottle which is near the front of the car by the bumper.
Check to make sure a few things
first does the pump make any noise when you press wash?
if not then look under the car where the bottle is to make sure it is plugged in
then the fuses as well.
is there fluid exiting under the hood. It may be too that the hose is not connected.
run it for a few seconds and see if there are any drips on the engine or under the car immediately after.
steviej
