2006 Gs Oil Change Question
Raise the front end. There is a large plastic splash guard. Up by the left front corner you will see a trap door seciton. 1 10mm bolt and one or two push pins keep it secure. Remove those and the flap drops down. You will see a cannister type of housing staring you in the face. There is an end cap that will receive a 3/8" ratchet or socket extension. Remove the cap. The plastic coupler inside the box with the new filter pushes up in hear (instructions on end oil filter box). This will drain the reserve in the cannister. The unscrew the cannister, remove the old filter. Put in new, screw cannister back in, replace end cap. Filter replaced.
steviej
  • 4 months later...
  • 1 month later...
