lsrxlex Posted July 25, 2005 Share Posted July 25, 2005 My local mechanic said that alignment should be done after changing the two steering rack cushions on my 1990 LS: "Grommet, steering", part # 45517-50010 and 45516-50011. Is there a way to avoid the alignment? Thanks. Quote Link to comment Share on other sites More sharing options...
nc211 Posted July 25, 2005 Share Posted July 25, 2005 I had mine replaced and didn't need one on my 95'. Quote Link to comment Share on other sites More sharing options...
GRAND_LS 4 Posted July 25, 2005 Share Posted July 25, 2005 Does it feel like it needs an alignment?? Quote Link to comment Share on other sites More sharing options...
lsrxlex Posted July 26, 2005 Author Share Posted July 26, 2005 My mechanic said since he has to remove both cushions at the same time, the rack and pinion would be completely detached. And after reinstallation, the steering rack might be "shifted to one side". I already told him that I just had an alignment done a month ago at Lexus dealer, but he said that won't help. I hope he is wrong. Quote Link to comment Share on other sites More sharing options...
RFeldes Posted July 26, 2005 Share Posted July 26, 2005 As Grand LS 4 said, Drive it after the change and see. Sears did an outstanding job on my alignment, for cheap, with computer print out and all. Drive-ability was night and day. Quote Link to comment Share on other sites More sharing options...
nc211 Posted July 26, 2005 Share Posted July 26, 2005 I fail to see why your mechanic has to detach anything to change those two cushions. It's two bolts to remove the U shaped cover and then it's pulling them off, putting the other on. They're split rubber, so it's not necessary to remove anything. Quote Link to comment Share on other sites More sharing options...
lsrxlex Posted July 26, 2005 Author Share Posted July 26, 2005 I'm sorry for the confusion. He meant he would have to remove those 2 bolts only, so the rack would be detached from that area of the chassis. I just wonder why removing these 2 bolts could mess up the alignment? Quote Link to comment Share on other sites More sharing options...
