billy hoang Posted July 24, 2005 Share Posted July 24, 2005 its a 1993 lexus ls400 . every morning when i come out , the rear of the car is always down . then when i turn the car on , the car raises up to normal height . is that normal ? well it didnt bother me before but i just put 20 inch wheels on and now when it lowers , the car basically sits on the tire . i ont want the tires to get damaged by this and i thought i read once that you can cut of the air suspension with a swqitch in the trunk ? is this true ? Quote Link to comment Share on other sites More sharing options...
lextsy Posted July 24, 2005 Share Posted July 24, 2005 Hi Im sure your rear air shocks have a leak. You will need to replace them which is like 900 a corner. I have read here also unplug your battery or something for 30 minutes to let everything reset try that first and if it doesnt work get new or 2nd hand ones If your lucky These will still be available http://www.clublexus.com/forums/showthread.php?t=169693 If you get them cheap it is a short term fix for your problem. I wouldnt really pay more than 200 each as they might go anyday however they might last a while. Maybe offer him 100 each see how nice he is? maybe he doesnt need the money all too much Quote Link to comment Share on other sites More sharing options...
lextsy Posted July 24, 2005 Share Posted July 24, 2005 if you cut out the air suspension switch in the boot the whole thing wont wont which means it wont even pump up in the morning. If it has a leak its got a leak. The reason to turn the swtich off is wen u jack up the car Quote Link to comment Share on other sites More sharing options...
billy hoang Posted July 25, 2005 Author Share Posted July 25, 2005 oh ok . so when i jack up the car .... why would i need to hit the switch ? and where is the switch located ? cause when i did jack up the car to do the brakes , whichover corner that was jacked up and then let down , it wouold go all the way down . Quote Link to comment Share on other sites More sharing options...
SW03ES Posted July 26, 2005 Share Posted July 26, 2005 Leaky air struts no ifs ands or buts. Happens to all of them at some point. Your best option is to replace with normal struts. Quote Link to comment Share on other sites More sharing options...
