:( anybody know anything about the time it takes and what is involved in the replacement of fuel injectors on a 98 gs300
To replace the injectors, will take you about 3 hours.
:( even if it is only one injector , do you think that all the injectors should be replaced????
No, not at all. It could be that your system just needs a good cleaning.
:( #2 injector failed they cost $212.00 apiece , very sad day for the nice ride, but will be fixed tommorrow.
Well look at it this way, ya do not need to replace them all. Did you find out why it failed?..
;) will find out after we can look over the old one , the injectors have been known to fail because of the spring inside the sealed injector you can not clean them to get them to work again .they have been known going at about 100,000 miles or so . and i only have 67,000???
:D well the car is fixed and runs better than ever it was #2 injector that failed and it was the internal spring the tech said that it is rare to see this problem , gotta hit the road see ya. :D :D :D :D :D
