Interior Lights Sanity Check
Allright I've seen some of these being discussed but there is always something left out. Correct me/fill the blanks if you can. So here goes:
Gauge Cluster:
- Needles: 9leds per needle, non repairable. Can it be replaced or does it require an entire cluster? Will lexus order only the needles?
- backlight bulbs. Repleacable? Whats the chance of the actual fuse/contact being damaged so changing the bulb makes no difference, like is it possible?
- Warning indicators: bulbs and they are replaceable right?
- Gear indicators: bulbs and they are replaceable right?
Is the backlight color bulb dependant or is it in the gauge face transparency itself?
Center Console:
- Climate control: bulbs, leds, combination of both? Which can be changed or is a new unit neccessary.
- Stereo: same as climate control?
Sunroof:
- i don't suppose the controls are lit up?
I am asking for the '93-97 models (mk1) as I am about to buy one and the lights issues are something that *will* happen. If not already present at purchase.
Cheers guys B)
