Seat Adjustment
I recently bought a used SC300 (1993) and now the passenger's seat won't move forward. Maybe it's off the tracks or something but the left side of the seat moves and the right side is stuck. I can't move the seat forward or backward at all. Instead it swivels to the right when i press the forward button and swivles back to the left when i press it backwards. has anyone had this problem before or does anyone know how to or the cost of fixing it?
i havent had this problem but see if anything is jammed down there to prevent your seat from moving. im not sure if the seat uses 2 motors to move but if it does then a motor might be out and those motors can cost some high dollars :(
take it to lexus and tell them not to fix it but to tell you whats wrong. it might cost some money but at least from there you can tell if you kan fix it or if they have to do it
