murthog Posted August 6, 2002 Share Posted August 6, 2002 I recently replaced all the disc pads on my 93 LS400. The brake wear warning light on the dash stayed on. I suspected that one of the wear sensors may have been damaged so I disconnected it. The light is still on. I disconnected all of the sensors. The light is still on. Does anyone know if there is a reset switch? thanks, Alan Quote Link to comment Share on other sites More sharing options...
UCF3 Posted November 22, 2002 Share Posted November 22, 2002 Have you tried disconnecting the battery, and seeing whether it goes off? Quote Link to comment Share on other sites More sharing options...
murthog Posted December 6, 2002 Author Share Posted December 6, 2002 Have you tried disconnecting the battery, and seeing whether it goes off? I did try that as part of a battery service and the brake light stays on. Quote Link to comment Share on other sites More sharing options...
UCF3 Posted December 10, 2002 Share Posted December 10, 2002 I would say, check the other brake pads, and rotors, to see if they are to blame. If that doesn't do the job, you might have to visit the local Toyota Dealer. Sorry. I know on my car the brake lights are still on after I changed the pads, and later I found out my rear rotors are running thin less than .25. on a side note I highly recommend checking underneath your car to see if there are any leaks from anything else. Good thing to know and good for preventative maintenance. Quote Link to comment Share on other sites More sharing options...
