ED. Posted June 16, 2005 Share Posted June 16, 2005 Seems like the trans acts weird when its cold. Feels like its slipping After the engine warms up its smooth as silk. Anyone else exprerience this after doing a flush and filter install? Do I need to add more oil? Less? Thanks Quote Link to comment Share on other sites More sharing options...
Kennyr Posted June 16, 2005 Share Posted June 16, 2005 Seems like the trans acts weird when its cold. Feels like its slipping After the engine warms up its smooth as silk. Anyone else exprerience this after doing a flush and filter install? Do I need to add more oil? Less?Thanks ← Setting the trans level can be tricky. Check it cold and hot several times and you will get it right. When a tranny is low on fluid it will slip till warmed up. Do not overfill it though. This usually brings on hard shifting. I've seen many times when the level was set and looked good after the service and then more needed to be added the next day after driving a bit. Quote Link to comment Share on other sites More sharing options...
ED. Posted June 16, 2005 Author Share Posted June 16, 2005 Thats exactly what its doin. When cold its slipping, especially in reverse, I will add another 1/4 quart when it cools down in a couple of hours. I didnt think it only neede 2 quarts. I'd say atleast two came out with the plug plus all the other that came out when I took the filter off. I am still having nightmares about thta dam thing : ) Thanks Kenny. I thought my transmission was ruined. Quote Link to comment Share on other sites More sharing options...
Kennyr Posted June 16, 2005 Share Posted June 16, 2005 Thats exactly what its doin. When cold its slipping, especially in reverse, I will add another 1/4 quart when it cools down in a couple of hours. I didnt think it only neede 2 quarts. I'd say atleast two came out with the plug plus all the other that came out when I took the filter off. I am still having nightmares about thta dam thing : ) Thanks Kenny. I thought my transmission was ruined. ← The car must be running in park when your checking the level. Also there is a hot and cold on the stick. Check it both ways in the next day or two. Quote Link to comment Share on other sites More sharing options...
Lexusfreak Posted June 16, 2005 Share Posted June 16, 2005 Seems like the trans acts weird when its cold. Feels like its slipping After the engine warms up its smooth as silk. Anyone else exprerience this after doing a flush and filter install? Do I need to add more oil? Less?Thanks ← How many miles on the tranny? When was the last time you did a tranny flush? Your owners manual should tell you the capacity for a regular 'drain & fill' but you might also want to consider doing a 100% tranny fluid change with the car hooked up to a special tranny machine. B) Quote Link to comment Share on other sites More sharing options...
ED. Posted June 17, 2005 Author Share Posted June 17, 2005 I just did the drain yesterday. I should have doem the shole system thign but I didnt really have time or money to give it to the dealer. I am hoping this is why. I wont know for a while. I put the Lexus in the garage and took the BMW. I am claybaring tonight. Wish me luck, its my first time. Well, gotta get to work! Thanks Quote Link to comment Share on other sites More sharing options...
