Tail Light Installation
Archie
To get to the tail lights on the rear 1/4 panel: pop the trunk and look in the crevice b/n the light housing and the weather stripping. You'll see 2 small plastic circles(that are screw covers). Pop those off with a small, flat screw driver with a taped blade. Remove the two philips screws that are now exposed; then, you just pull the assembly right out and replace what you need. These lights are accessable from outside the trunk.
The lights on the trunk come out quite easily. Open the little trap door that is behind the lights and remove 1 philips screw. The little assembly that holds the lights comes straight out and you can then replace them. These lights are accessable from inside the trunk.
:cheers:
