Fuel Filter Change
first off good luck you will need it. second it is under the car just behind the rear driver side tire. i suggest spraying the fittings with some WD 40 a couple of times a day for about three days then trying to remove it. try not to brake the lines it will be really expensive to fix. let me know how it turns out
I did it and I'd reccomend 2 vice grips and somehow to stop the fuel line, otherwise get a pan underneath and try to salvage the expensive fuel you'll lose.
