Hello, newbie here, I apologize in advance if this has been covered before. I have two questions relating to a rim & tire set i'm thinking of putting on a ES300.
First off, correct me if i'm wrong, but the bolt pattern is 5x114.3, right? So would it be possible to put a 5x115 rim on a 5x114.3 hub? I've heard of 5x114.3 rims fitting on a 5x115 hub with the addition of a centering ring to keep the rim centered on the hub. I wondered if this was the case the other way around.
Second, the rims are 17" x 8" with 255/45/17 tires with a 35mm offset. Would this width work? The tires are quite wide and i'm concerned if rubbing on the inside of the tire will be an issue.
Thanks in advance
You didn;t read the FAQ did you
A spacer will not work on an ES as their is not enough room.
a 255 tire will never fit
you need a 43mm offset rim
X 8 is as wide as you want to go
I did read the faq above before posting and there is not one word in there about bolt patterns, offsets or centering rings. I didn't ask about spacers, maybe you need to read the faq again.
