Icarus Posted May 27, 2005 Share Posted May 27, 2005 One day may seats/windows/trunk/and gas tank lid would not work. Checked manual and found fuse that was blowing (either 17 or 19 in the kick panel --30amp) and went to Autozone and bought fusible link fuse... blows that too. Disconnected the seats and windows and still blows. The fuses look similar, but not exact (square fuses). Took fuse out of slot 15, thinking that I have the wrong style fuses, which was also a 30amp and blew that too. Then put fusiible link fuse from Autozone back in 15 and got ABS light on, power steering too hard, and have to use shiftlock overide to get into gear. Took to Lexus dealer...ouch, they pushed on fuse 15 when running and ABS light went out/streering o.k./driver's window and sunroof worked. Restarted and same got problem again and pushed fuse and again fixed that problem. They determined that there is a short in the fuse block and want to replace for $850.00. They blame aftermarket remote start installed by Best Buy. Any advice on fuse type or repair? This is my first post. Quote Link to comment Share on other sites More sharing options...
Icarus Posted May 28, 2005 Author Share Posted May 28, 2005 Anyone out there? :whistles: Quote Link to comment Share on other sites More sharing options...
JDOwen2 Posted May 28, 2005 Share Posted May 28, 2005 If the trouble started after Best Buy installed the remote start feature I think I'd be talking to Best Buy next. $850.00 sounds steep to me but Lexus is proud of their work. You could pick up a used fuse block cheap and replace it yourself. Quote Link to comment Share on other sites More sharing options...
Icarus Posted May 28, 2005 Author Share Posted May 28, 2005 are the straight-forward to replace? I have done the shocks,plugs,wires,cap&rotors... that kind of thing so far. Quote Link to comment Share on other sites More sharing options...
Icarus Posted May 28, 2005 Author Share Posted May 28, 2005 anyone ever replace a fuse bloc k? Quote Link to comment Share on other sites More sharing options...
