I posted this message March 2005 and received no replies that I could ascertain. It looked like I got about 26, but I couldn't find them. Thought I would give it another shot and see if anybody has a response.
Found out how to pull bezel
Remove the following clip on parts:
The simulated wood cover cover around the shift lever
The cover on the dash that has the 12vt source
Both these itms snap off
Remove four bolts that hold the radio panel. All bolts are 10 mm. Two of these bolts are about 2 inches into the dash. Suggest magnetic socket. Two are up front and easily seen (leave the black screws alone)
Remove the radio and bezel from the dash (cliped at this point)
Remove the upper navigation and bezel by removing two bolts and then pulling to unclip.
The bezels are attach to the radio and the Navigation display (Info Only)
There are two connectors going into the nav system NONE COMPLIES WITH THE REFERENCED COLOR CODE BELOW.
Does anybody have the proper color code to perform the below modification and which connectors are they attached? This becomes a little bit trickie because there are the same colors going into the driver side and passenger side connectors on the nav unit.
March 2005
I have a RX 330, 2005 model. I would like to play DVD's through the navigation system; I understand that this may not be possible because of the coding charactorists of the player vis-a-vis the disk (incompatable systems) I would appreciate a comment or two on this subject.
I would also like to bypass the DVD lockout when the vehicle is in motion. I have found www.rocoto.com/siennamods/body_dvd_mod.html
that speaks to this modification on a 2004 Sienna. It appears to be very simple task.
My question pertains to the wiring diagram supplied at this web site:
1. Are these the same color code as on the RX330......... THE ANSWER IS NO!
2. Where may I find info on removing the bezel. (Toyota does a remarkable job of hidding entry points!) see above
Sorry, i don't know how to do what you need spicificaly.
All i do know is that the 05 es navigation is a piece of work. It's even hard to use the navi, nevermind add dvd to it lol
good luck.
afterburner1:
Pretty interesting, have you looked through the TIS (http://techinfo.lexus.com/)? This is a great resource.
I am installing a Parrot CK-3100 (Bluetooth Adaptor) to my 2004 Lexus RX330. The TIS is going to be my walk through on how to remove the hardware. I am also interested in disabling the VSS.
Thanks for the info, and take a look at TIS.
Nav
  • 1 month later...
Did you hear back from anyone on how to disable the parking brake sensor and motion sensor for full functionality of Navigation and DVD?
