tshrtkng Posted May 20, 2005 Posted May 20, 2005 I was wondering if anyone knows about other options for inputting mp3 or other audio. I saw the one for The Vais technology unit for the Apple Ipod someone listed at http://www.emba42.com/lexus/, but I want to us my IPAQ or other mp3 type device. I would like to have a unit that will accept a headphone type jack rather than a proprietory plug for a single unit. Any ideas???
074XG Posted May 20, 2005 Posted May 20, 2005 Go back to the Vais website and look carefully at all the adaptors they offer. They make an AC-100 which is just and audio interface. The module allows you to hook up two seperate audio sources. The module has 2 sets of RCA inputs. I got one recently and I use one set for my MP3 player (I got an adapter that goes from headphone jack to RCA) and the other set I use for my DVD player for audio only. You switch between sources from your steering wheel and its a direct connection to the radio so you don't get any audio noise, loss or interferance. Sounds and works great! Heres the link to the website http://www.vaistech.com/aic100.html Good luck
indiasfinest Posted May 21, 2005 Posted May 21, 2005 Go back to the Vais website and look carefully at all the adaptors they offer. They make an AC-100 which is just and audio interface. The module allows you to hook up two seperate audio sources. The module has 2 sets of RCA inputs. I got one recently and I use one set for my MP3 player (I got an adapter that goes from headphone jack to RCA) and the other set I use for my DVD player for audio only. You switch between sources from your steering wheel and its a direct connection to the radio so you don't get any audio noise, loss or interferance. Sounds and works great! Heres the link to the website http://www.vaistech.com/aic100.htmlGood luck ← ok well i have an alternate solution, a much cheaper solution, go to fry's and u can by something that will plug into your ac adapter. then u can plug your mp3 player, usb flash drive, or cd player into there. it will transmit it to the radio at a certain station and you can listen to it from there. it ranges from $20 to $30. now u will sacrifice some soud quality but its worth it.
Neo Posted May 23, 2005 Posted May 23, 2005 it will transmit it to the radio at a certain station and you can listen to it from there. it ranges from $20 to $30. now u will sacrifice some soud quality but its worth it. ← This is the point. I do not think tshrtkng wanted to sacrifice sound quality which is why he was looking for a direct connection instead of a cassette adapter or an FM unit.
