jadsc300 Posted May 19, 2005 Posted May 19, 2005 Hi all: I have a 1999 SC300 the only problem it has is that a green indicator light starts flashing on the A/C button. This only occurs when the A/C is turned off and after about 10 or 15 minutes. When it starts to flash - I press the "off" button and it stops but then starts again after another 15 minutes or so. The A/C runs fine and doesnt flash when its on - only when its off. I ran the self diagn. test and it gave me the "00" meaning normal. I've done some research but im clueless. Any suggestions before i get a big bill from the dealership?? PLEASE!!!
Lexusfreak Posted May 21, 2005 Posted May 21, 2005 If the air cond is working fine & nothing mentioned in the owners manual about your concern, I would think there is nothing to worry about. B)
jadsc300 Posted May 23, 2005 Author Posted May 23, 2005 yea but the green flashing light wont stop!! It's annoying!!
mburnickas Posted May 23, 2005 Posted May 23, 2005 yea but the green flashing light wont stop!! It's annoying!! ← My 98 ES does that when I use the AC and then park on hot days. Per my book this is normal. It does stop when I start moving if not, it blinks till the engine temps goes down. I would look in the book for something.
jadsc300 Posted May 23, 2005 Author Posted May 23, 2005 cool thanx - mine will just keep blinking till I hit the "off" button and it only blinks when the A/C is turned off it never blinks when i have the A/C on - the book said to take it to the dealership (figure$)
Lexusfreak Posted May 24, 2005 Posted May 24, 2005 Any warranty remaining on it (Lexus Extended coverage perhaps?)
jadsc300 Posted May 24, 2005 Author Posted May 24, 2005 only on the powertrain - i don't suppose that helps much - I'm thinking about taking it to the dealership just to find out what it is - I'm buying new tires and brakes this week so I'l b broke!!!! :(
GRAND_LS 4 Posted May 26, 2005 Posted May 26, 2005 only on the powertrain - i don't suppose that helps much - I'm thinking about taking it to the dealership just to find out what it is - I'm buying new tires and brakes this week so I'l b broke!!!! :( ← In my owners manual, it says if the light is flashing, something is wrong with the compressor.
Lexusfreak Posted May 27, 2005 Posted May 27, 2005 only on the powertrain - i don't suppose that helps much - I'm thinking about taking it to the dealership just to find out what it is - I'm buying new tires and brakes this week so I'l b broke!!!! :( ← What is the exact tire size you need & what tires are your considering? Perhaps I can assist with suggestions. B)
mburnickas Posted May 27, 2005 Posted May 27, 2005 only on the powertrain - i don't suppose that helps much - I'm thinking about taking it to the dealership just to find out what it is - I'm buying new tires and brakes this week so I'l b broke!!!! :( ← In my owners manual, it says if the light is flashing, something is wrong with the compressor. ← I agree if it blinks all the time. If it blinks then shuts off, then it is fine. I know why mine blinks when there is no freon traveling to cool it, it is too hot. It does this after stopping the engine in hot weather. Then once I restart (ie 10 minutes later it blinks till the compressor has time to move the freon.
jadsc300 Posted June 9, 2005 Author Posted June 9, 2005 My light never stops blinking untill I hit the "off" button - Is it possible I just need a recharge?
scoobiedoo Posted June 9, 2005 Posted June 9, 2005 My light never stops blinking untill I hit the "off" button - Is it possible I just need a recharge? ← You might want to get it recharged at an AC shop for $50-$100 to see if that solves the problem, if not then bring it to the dealer.
