VT FIJI Posted May 17, 2005 Share Posted May 17, 2005 The power lock on my passenger side door seems to have crapped out. The switch works fine; it's the actual power lock that doesn't work. You can manually lock and unlock it by sliding the "toggle switch/lock." (does that make sense?) So far, I removed the trim around the door handle. I also removed the screw below the tweeter and started prying from there. I managed to work my way down and around to the other side, removing 3 out of the 4 sides. I can't seem to get the top portion of the door panel off. Am I forgetting to remove any screws? or should I just give it some more force? Any help is much appreciated. Thanks in advanced. btw, it's a '99 ES300 Quote Link to comment Share on other sites More sharing options...
justin97 Posted May 17, 2005 Share Posted May 17, 2005 The power lock on my passenger side door seems to have crapped out. The switch works fine; it's the actual power lock that doesn't work. You can manually lock and unlock it by sliding the "toggle switch/lock." (does that make sense?)So far, I removed the trim around the door handle. I also removed the screw below the tweeter and started prying from there. I managed to work my way down and around to the other side, removing 3 out of the 4 sides. I can't seem to get the top portion of the door panel off. Am I forgetting to remove any screws? or should I just give it some more force? Any help is much appreciated. Thanks in advanced. btw, it's a '99 ES300 ← :D http://us.lexusownersclub.com/forums/index...l=door++removal Quote Link to comment Share on other sites More sharing options...
VT FIJI Posted May 17, 2005 Author Share Posted May 17, 2005 Thanks for the link. After all that work removing the door panel, I decided it was too much work going any further. I'd have to remove too much stuff to get down to the power lock mechanism. Thanks for all the work though. Quote Link to comment Share on other sites More sharing options...
justin97 Posted May 17, 2005 Share Posted May 17, 2005 Thanks for the link.After all that work removing the door panel, I decided it was too much work going any further. I'd have to remove too much stuff to get down to the power lock mechanism. Thanks for all the work though. ← my button has crapped out on me on the same side, then one of my friends broke it. so u cant unlock it or lock it from the pass side maybe that is what is wrong with yours. door is simple to get off take like 10 minutes takin yor time. Quote Link to comment Share on other sites More sharing options...
VT FIJI Posted May 20, 2005 Author Share Posted May 20, 2005 my button has crapped out on me on the same side, then one of my friends broke it. so u cant unlock it or lock it from the pass side maybe that is what is wrong with yours.door is simple to get off take like 10 minutes takin yor time. ← It's not the actual switch. If I hit the power switch, it will lock/unlock all the doors. The problem is with the actual power lock. Does anyone have a link to the actual power lock mechanism? If it's not too complicated, I would like to try to fix it myself. Do you think it's a feasible job or should I bring it to the dealer? Quote Link to comment Share on other sites More sharing options...
