Rotor Screw
Jacob
I was trying to replace my front brake pads and have the rotors resurfaced. Unfortunately, I stripped the head of one of the two screws that hold the rotor. Any ideas on how to fix the problem? And what size screw driver should I use for the remaining screws.
1996, LS400
Thank you,
There is a special drill bit made that was meant to remove stripped screws and bolts that have had the heads snapped off by overtorquing them. Try Sears or a good hardware store
