mykelbixler Posted May 12, 2005 Posted May 12, 2005 Had some questions about IS300 specs whats the whp on the stock is300? is there a way to get 290whp not forced and a daily driver? I ask because a friend of mine has a 91 civic hatch with a stock rsx type-s swap and I'm tired of being slower then him. I figure using the whp to weight ratio. His car has a curb weight of 2100lb and 180whp he's getting around .086 whp per pound. Earlier I asked what the curb weight of the IS is because I just guessed at about 200. Which means that with a curb weight of 3200lbs and 200whp I'm getting about .062 hp per pound. Do some math...... if I can get about 275whp I should be the same as my friend, 290whp and I'll win Hence the reason for the next question....how to get 290whp with reliability, a daily driver and I dont want forced.
bartkat Posted May 12, 2005 Posted May 12, 2005 WHP of a stock IS is more like 175 - 185. I doubt you're going to get close to 300 WHP without going FI.
mykelbixler Posted May 12, 2005 Author Posted May 12, 2005 Had some questions about IS300 specswhats the whp on the stock is300? is there a way to get 290whp not forced and a daily driver? I ask because a friend of mine has a 91 civic hatch with a stock rsx type-s swap and I'm tired of being slower then him. I figure using the whp to weight ratio. His car has a curb weight of 2100lb and 180whp he's getting around .086 whp per pound. Earlier I asked what the curb weight of the IS is because I just guessed at about 200. Which means that with a curb weight of 3200lbs and 200whp I'm getting about .062 hp per pound. Do some math...... if I can get about 275whp I should be the same as my friend, 290whp and I'll win Hence the reason for the next question....how to get 290whp with reliability, a daily driver and I dont want forced. ← I do have tourqe in my favor because of the inline 6...so increasing whp will also up the tq...so really I'd need more like 255-265whp maybe that'll be more reachable goal
mykelbixler Posted May 12, 2005 Author Posted May 12, 2005 the question is then, are there enough non-FI mods to add 75-85whp?
bartkat Posted May 12, 2005 Posted May 12, 2005 the question is then, are there enough non-FI mods to add 75-85whp? ← I don't think you can easily do it with bolt-ons. Might need some electronics and some internal work. My guess would be 50 HP gain max without spending thousands of dollars. Maybe do a google search or something on NA IS300 or Supras, and see who's got the best times with what mods. Most of the guys I know have gone with turbo.
