CatKing Posted May 2, 2005 Share Posted May 2, 2005 hi all, is there anybody out there had taken away their spare tire from the rx330. other than flat tire occassion, are there any disadvantages from it. i think if it is not usually happened and i can call for towing once it occur, what is good to keep it there? thank you for your advice if any. Quote Link to comment Share on other sites More sharing options...
dal Posted May 2, 2005 Share Posted May 2, 2005 hi all,is there anybody out there had taken away their spare tire from the rx330. other than flat tire occassion, are there any disadvantages from it. i think if it is not usually happened and i can call for towing once it occur, what is good to keep it there? thank you for your advice if any. ← One factor to consider in your decision: spare tires do provide a level of impact protection in a rear-end collision. Quote Link to comment Share on other sites More sharing options...
denslexusgx470 Posted May 2, 2005 Share Posted May 2, 2005 another thing (for those really picky about cars) It hides the under part of the car so people don't easily see if it's dirty or clean (if it's clean, under part is usually nice and black, usually the conditon before used in rain). Quote Link to comment Share on other sites More sharing options...
TunedRX300 Posted May 2, 2005 Share Posted May 2, 2005 hi all,is there anybody out there had taken away their spare tire from the rx330. other than flat tire occassion, are there any disadvantages from it. i think if it is not usually happened and i can call for towing once it occur, what is good to keep it there? thank you for your advice if any. ← I took it off my RX300 to shave off almost 50 lbs of dead weight. Instead I have a fix-a-flat can for slow leaks. Drawback is you lose the option of jacking up a flat and replace with spare w/o calling the tow truck. Quote Link to comment Share on other sites More sharing options...
CatKing Posted May 2, 2005 Author Share Posted May 2, 2005 hi, thanks all for the input and that are all i am thinking about. the most concern is i can take away some weight from the vechicle provided that that is no harm to it liked if rear-end collision happened. Quote Link to comment Share on other sites More sharing options...
