damesta Posted April 26, 2005 Share Posted April 26, 2005 Hey guys, I'm about to pick up an sc400 and just wanted to check on some wheel offsets with you guys. The wheels I want are 17x7 +35 front and 17x8 +35 rear. Would these fit ok? Ive done a little research and it looks like it will be a little aggressive but seems like it would work fine with a little negative camber. Does anyone have any opinions or reccomendations on tire size to run with these? Any help is greatley appreciated. Thanks Quote Link to comment Share on other sites More sharing options...
JDOwen2 Posted April 27, 2005 Share Posted April 27, 2005 Stock wheel offset is 50mm. You could use spacers to get the 50mm spacing. It's doubtful you would notice the slight change in offset. Make sure the new wheels clear your rotors. Quote Link to comment Share on other sites More sharing options...
