nycgs300 Posted April 20, 2005 Share Posted April 20, 2005 Hi all, I'm about to hook up an after market amp.(sony). What I would like to do is to run the remote wire from the amp. to the back of the head unit. So I want to know if the head unit does have the remote wire. This is for when I turn off the head unit the amp. should also turn off too. One more thing I like to know is...is there a pre-opening between the inside cabin and under the hood so I can run the power line to the battery or do I have to drill a hole? Thanks... Quote Link to comment Share on other sites More sharing options...
TurboGS300 Posted April 20, 2005 Share Posted April 20, 2005 You have to drill a hole! I did my 2awg on the passenger side. Yes, the deck has a remote wire to turn on the factory amp in the rear <_< Quote Link to comment Share on other sites More sharing options...
nycgs300 Posted April 20, 2005 Author Share Posted April 20, 2005 You have to drill a hole! I did my 2awg on the passenger side. Yes, the deck has a remote wire to turn on the factory amp in the rear <_< ← Thank you so much!!! Quote Link to comment Share on other sites More sharing options...
TurboGS300 Posted April 20, 2005 Share Posted April 20, 2005 BE VERY CAREFUL when drilling!!! Check 4 times drill once <_< Quote Link to comment Share on other sites More sharing options...
