I looked at some of the posts relating to this, but it wasn't clear to me as to what the difference is between the Supra and the LS400 brake upgrade. Appreciate if someone could briefly tell me the difference between the two different calipers.
i am 99% sure that the front calipers have the same performance (about the same as a ferrari F40)
I believe performance is similar. They look different. They are both big and heavy. ;)
Here is what the calipers look like (just look at the shape and not the stickers):
SupraTT:
LS:
Per intellexual.net
LS400:
caliper weight - 9 lbs
rotor diameter - 12.4 inches
rotor thickness - 1.26 inches
Supra:
caliper weight - 15 lbs
rotor diameter - 12.72 inches
Personally...I'm not sure whether to trust the accuracy of the weights given. From the pictures...they both look like they are sized very similar (both are 4 piston calipers). The rotor diameters are close, and the thickness is the same. So I find it a little difficult to believe that there is a 6lb difference in weight. Not saying that this can't happen...but I'm not sure if I trust the info.
LS400:
Supra:
Now that you've posted the numbers, they jog the memory a litte. I had thought the front rotor for the LS was a tiny bit smaller but the rest looks about right.
yea thats right you can follow the tutorial that AWJ did but they are with the TT calipers, but basicly the same thing but with the LS calipers.
