Hello,
I am having some noise problem in my 97 ES300.
while checking everything one by one i found that
front fender on driver side making noise. passanger
side looks solid and no noise by hitting on it.
How to open ?How to fix it?
or
take it to bodyshop?
Thanks,
Your description is a little too vague. :wacko:
What type of noise is it.......a rattle, squeaking, or what?
squeaking
OK.....now, does this sound happen when you hit a bump, or while making a turn, and at what particular speed? As I said before.........it's almost impossible to diagnose a problem unless you describe it more fully. <_<
this sound happen when I hit a bump at 5-10 mph.
It could be making this noise due to a bad strut. You should bring the car to a qualified mechanic, not a bodyshop to check this out.
As you know, I have 97 ES300. I changed following items.
Front Lower arm controller bushing. (Both)
Front KYB struts and mounts.(Both)
Front stabilizer bar bushing. (Both)
and all engine mounts
And, still I am hearing some noise comes from front when I go over speed bump.
Are you near DFW? Even if you aren't, drive in and let JP Importz look at your car. He'll get it all taken care of. I drive 4 hours each way(from LA) to JPI because their service is that good and is very reasonably priced.
685.00 Lower Control Arm Bushing & Front Struts & Mounts (KYB)
130.00 Rear Mounts (Parts Only)(KYB)
140.00 Rear Struts (Parts Only)(KYB)
50.00 Labor to Install rear Struts & Mounts
160.00 front and Rear Stabilizer Bushing (Parts & Labor)
125.00 front engine mount
50.00 rear engine mount(Pack in)
45.00 dog bone mount
45.00 Transmssion mount
120.00 Total labor for 3 mount (i put dog bone on it.)
$1550
Hope this help.
Mechanic fix the front fender noise. But still that squeaking noise is comming when i go over speed bump. only thing i didn't change is the shock which is close to front engine mount. I did open top bolts and then try to pull and push by hand.
yes it was moving by hand. so my question is: is that normal?
Thanks,
