tleader Posted June 26, 2003 Posted June 26, 2003 I have the Nakamichi radio in my 91 Ls and only the right side sounds like it is playing to the full volume. The left side of the car is playing, but really low in volume. Anyone have any suggestions for a fix on this problem. Could it be the amp, and if so, where is it located. Thanks
SKperformance Posted June 29, 2003 Posted June 29, 2003 is this problem from all sources as in the cd tape and radio it might be the volume control does it crackle when turned at all?
rstreich Posted July 22, 2003 Posted July 22, 2003 I have the exact problem you described: left channel has minimal output from tuner and CD (don't know about tape) and it crackles a bit when you adjust the volume. It sounds like you know what the problem is. Care to share it? thanks -r
