Kennyr Posted March 26, 2005 Share Posted March 26, 2005 My 91 LS400 with 145k miles cranks too long before starting at times. It always starts. The plugs and wires etc. are all new. I've tried all grades of gas with no difference. Any ideas? Quote Link to comment Share on other sites More sharing options...
Lexls Posted March 26, 2005 Share Posted March 26, 2005 Worn starter, weak or dying battery, worn distributors & caps......it could be many things. I wouldn't worry about it until it doesn't start ;) Quote Link to comment Share on other sites More sharing options...
914lps Posted March 26, 2005 Share Posted March 26, 2005 Worn starter, weak or dying battery, worn distributors & caps......it could be many things. I wouldn't worry about it until it doesn't start ;) ← Try turning the ignition on, but not starting the car. Count to 20 and then try starting the car. If it starts faster after doing this it is most likely a fuel pressure thing. When sitting the car looses fuel pressure in the line, and has to let the fuel pump rebuild it as it cranks. By just turning the ignition on, you are giving the fuel pump a chance to build pressure. That's all if waiting the 20 count does anything.... Another question. If you start the car and have it running, then shut if off, but restart it immediately does it still take time to start???? Quote Link to comment Share on other sites More sharing options...
maxed_out Posted March 27, 2005 Share Posted March 27, 2005 Agree fuel pressure possible. Could be cold start injector :whistles: Whens the last time you cleaned the injectors? I started using seafoam which works well. Quote Link to comment Share on other sites More sharing options...
914lps Posted March 27, 2005 Share Posted March 27, 2005 Agree fuel pressure possible. Could be cold start injector :whistles: Whens the last time you cleaned the injectors? I started using seafoam which works well. ← Maxed Out... Never heard of SeaFoam. What is it were do you get... Quote Link to comment Share on other sites More sharing options...
maxed_out Posted March 27, 2005 Share Posted March 27, 2005 914lps, Seafaom is an engine additive. Also sold as "deep creep" in a spray can. http://www.seafoamsales.com/products.htm I dont work them, just read about it, lots of folks pretty pleased and I tried it and was amazed. Picked it up at Autozone for 5 a can. Quote Link to comment Share on other sites More sharing options...
