dan83 Posted March 10, 2005 Posted March 10, 2005 My 1992 sc 400 virbates severely at 70 mph, suspecting the Universal joint in the driveshaft, but my local lexus dealer says i can only buy the whole shaft assembly with all the seals and center support bearing for over $800. where can i get just the universal joint? dan
TMaxxTim Posted March 10, 2005 Posted March 10, 2005 My 1992 sc 400 virbates severely at 70 mph, suspecting the Universal joint in the driveshaft, but my local lexus dealer says i can only buy the whole shaft assembly with all the seals and center support bearing for over $800. where can i get just the universal joint?dan ← Are you sure its not a wheel thats out of balance. You can not notice a wheel out of balance until you get to a certain speed. Does it stop after a certain speed also? What makes you think driveshaft?
dan83 Posted March 11, 2005 Author Posted March 11, 2005 it only vibrates from about 70-75, i think it is not the wheels because the vibration changes depending upon whether i am accelerating or coasting with no throttle. The tires are badly worn and i will be replacing them anyway. at the moment i am considering the driveshaft replacement with center bearing from driveshaftstore.com for $397.00. Lexus wants over $800. Any suggestions? dan
jzz30 Posted March 11, 2005 Posted March 11, 2005 its most likely your trans mount, and possibly your motor mount also but more the trans mount. try change it first its only like 60 bucks and only takes like 20 min to change.
nc211 Posted May 24, 2005 Posted May 24, 2005 Just curious, any update on this thread? Dan, did you get it fixed? Driveshaft?
