digadigado Posted February 25, 2005 Share Posted February 25, 2005 I've been reading with great interest all the excellent detailing advice. However, I've got a slightly different problem. My new-to-me 2001 ES300 has many, fine scratches all over the lower, flat surface of the walnut console (around the shift lever). I suspect is was poor cleaning and polishing by the prior owner. Any suggestions on how to get them out of the plastic(?) finish over the walnut? Thanks! Patrick Quote Link to comment Share on other sites More sharing options...
SW03ES Posted February 26, 2005 Share Posted February 26, 2005 I would reccomend you use a light polish, if you want something availiable locally you could use Meguiars ColorX. Polish it out using straight strokes and it should come out ;) Quote Link to comment Share on other sites More sharing options...
TOGWT Posted February 26, 2005 Share Posted February 26, 2005 Megs ColorX might be a little harsh for plastic,although it works very well on paintwork I would suggest using a Plastic Polish (Megs #17) if this does not remove them then 'step-up' to a more abrasive polish Trim cleaning: The wood trim in most vehicles (Mercedes Benz uses real wood) is protected with a urethane clear coat, polyurethane or a thin lacquer, which is very easily scratched. Remove scratches with a fine polish (Meguiar's #17 Clear Plastc Cleaner / 10 Plastic Detailer, or Groit's Fine Hand Polish) and then wipe with a damp 100% cotton towel. Maintenance- use an anti-static plastic cleaner protectant (BTI Chemicals Plexus@ Glass Polish & Cleaner) JonM Quote Link to comment Share on other sites More sharing options...
SW03ES Posted February 26, 2005 Share Posted February 26, 2005 I've used polishes like the ColorX on real wood panels before and never had a problem. In my experience if you can use it on paint, you can use it on real wood trim. I agree you should always try the least aggressive step first though. Quote Link to comment Share on other sites More sharing options...
digadigado Posted February 26, 2005 Author Share Posted February 26, 2005 Thanks guys, for the advise! I'll start out with the most conservative technique and work my way up. Afterwards, I'll post the results for the next person who has this problem. Thanks again, Patrick Quote Link to comment Share on other sites More sharing options...
TOGWT Posted February 27, 2005 Share Posted February 27, 2005 I've used polishes like the ColorX on real wood panels before and never had a problem. In my experience if you can use it on paint, you can use it on real wood trim.I agree you should always try the least aggressive step first though. ← Quote Link to comment Share on other sites More sharing options...
lexus ls430 Posted March 15, 2005 Share Posted March 15, 2005 i would take it to a perfessional Quote Link to comment Share on other sites More sharing options...
SW03ES Posted March 15, 2005 Share Posted March 15, 2005 Why? Its something he can easily learn to do himself and he'd be better for the experience. Quote Link to comment Share on other sites More sharing options...
