Engine And Transmission Mount
AlmightyLexus97
Usually the engine mount will last a bit longer than the transmission mount. A bad transmission mount will cause the rear of your car to vibrate when going 65mph+. A bad engine mount will cause your front to vibrate while idling. I think you can DIY the engine mount. I replaced my transmission mount at a local Toyota dealer for $150
