thisisludicrous Posted February 14, 2005 Share Posted February 14, 2005 Less than a year ago, I picked up a set of Silverstar bulbs for my headlights on my 95 LS400. I was very pleased with the results, if less than wholly satisfied with the almost-$40 pricetag for two of them. Now, one of my lowbeams has already gone out. (Yes, I'm POSITIVE I didn't touch the bulbs with my fingers) Rather than shelling out $20 for another Silverstar, is it possible to simply install a $10-or-less regular replacement bulb, then aim the headlight slightly higher for better illumination - hopefully without blinding oncoming traffic? Anybody tried this before? I remember with the old bulbs, it seemed like I could barely see more than 6 or 7 car lengths in front of me. But they lasted a while... Thanks in advance for any input. Quote Link to comment Share on other sites More sharing options...
silvermate Posted February 14, 2005 Share Posted February 14, 2005 a years use out of them is pretty average, i had mine in for 2 years, and wanted to try some others. no, another bulb will not work........it won't match, and/or the beam pattern and light output will not be the same. Silverstar bulbs are bright white and wouldn't match a regular "yellow" type of bulb. it would look like crap your options are: 1 buy a replacement silverstar 2 buy a new set of bulbs Quote Link to comment Share on other sites More sharing options...
1990LS400 Posted February 14, 2005 Share Posted February 14, 2005 Wagner BriteLite Xenon bulbs seemed to last a lot more than a year on my 90 LS. Whether they have any Xenon gas in the bulb is a matter of debate. I can, however, tell you that these uncoated bulbs produce much whiter light than standard bulbs. I think they draw the standard wattage which might be why they last longer. They seem to sell for about $10 each both locally and on-line like from this seller: http://www.brandsport.com/w9003.html Aiming your lights higher than spec is really bad for us old folks who have enough problems with glare from on-coming car's headlights. Quote Link to comment Share on other sites More sharing options...
thisisludicrous Posted February 15, 2005 Author Share Posted February 15, 2005 Sorry, gents, I wasn't very clear. If I would go back to regular 'yellow' bulbs, then I would definitely replace both headlamps, not just one, because Silvermate, you're absolutely right, that would look ridiculous. But going back to the yellow bulbs, hopefully for a longer life, would also mean the decreased illumination distance I had before. So that was my other question, could I aim the headlights a little higher to achieve more than 6 car lengths of illumination. My thinking is that in aiming the headlights higher, I would simply come up to par with what most other vehicles on the road have, roughly 10+ car lengths of illumination. But as 1990LS400 pointed out, I certainly would not want to exceed this, otherwise I'm blinding folks. I'll definitely check out brandsport.com, thanks for the tip! Quote Link to comment Share on other sites More sharing options...
