I want to get snow tires for the RX 330, I have a 2004 with 18" wheels. Has anyone got snow tires for their RX? If so, what do you recommend, its hard to find snow tires to fit this car.
According to Tirerack, this is the only 18" winter tire in your size that will go on your RX...click the link:
http://www.tirerack.com/tires/Compare1.jsp...ing=ZR&x=66&y=7
:cheers:
You may have better luck in a smaller rim size. Maybe get smaller winter rims at the same time.
I agree....more selection if you move down to 17". B)
:cheers:
I would move down to 17s also, a little more initial investment having to buy wheels too but it also makes it easier to swap the tires come spring.
An excellent winter SUV tire would be the Toyo Open Country G-02 Plus. They come in the 17" tire size you need & you can just switch the tires on your existing rims if you choose to.......no need to get an additional set if you didn't want them. B)
:cheers:
