Hello,
Let's see we together solve the problem.
As you all know that I used refurbish PSP for my ES300.
On high pressure side it is leaking.( I can say Swiping(Sweeping), Hope my spelling correct).just one drop after all day driving. but I like perfect job.
How to fix this problem.
Thanks in advance.
Did you use tefon tape on the install? PSP have tapered fittings and do not need sealent tapes or paste. There may be a burr in the threads, it may not be tourqued down enough, or you may have a pin hole leak near the connector.
Good luck with it, keep us posted.
TT
Teflon tape?
where
did you buy new metal gaskets and clean the old surfaces properly
probably not which gouged the aluminum gasket and made it leak
get a new set and do it again
