I'm new to the forum and imagine this question has been addressed before. I have a 1993 ES300 and lately at least two of the instrument bulbs have gone out. Are they easy to replace. Can someone give direction on getting the instrument cluster out? I'm mechanical so can handle most anything.
There are 2 screws on the top inside of the cluster housing [ covered by drop down tabs ] remove them and the housing pulls straight out , there is a wire connector on the bottom - disconnect and remove , Then there are 4 screws 2 on top and 2 on the bottom remove them and pull the cluster out and disconnect the 3 plugs on the back and remove , reverse order for install. Good luck it is easy.
