Removing The Dashboard...
1991LS400
If anyone knows how to remove the dashboard of a 1991 LS 400 (90-94 LS) or has removed the dashboard before, please let me know.
If these guys in Japan can customize their LS's interior with different paints on the dash and all that jazz then I know it's possible.
Someone help, please!
Sure it is possible if you have about 8 hours to spare
you'll have to remove the
center console
trim on a pillars
all lower dash shrouds
radio
climate control
cluster
vents
you may have to remove the steering wheel
and everyother small part on the dash
I would never recommend anyone ever remove a dash unless it was detremental
as afterwards it WILL rattle and squeek like made if not perfectly refitted which i have never seen
and if you forget one small part like a curve in the vent piping it won;t work
a very detailed heavy and long job to do especially without the OEM lexus service manual showing where everysingle screw bolt nut and fastener is
