Gs 98-03 Navigation
It can be done, but will take some work since the volume control and other controllers will have to be relocated eslewhere or you will need some sort of controller to replace that. I think it would be much easier if you would swap out the factory cd player with the dvd player and go from there!!!
I'm also interested in installing video into my GS also but would like to keep my factory navi system. Found this link at the a/v section of of LOC Check this out---->Vidieo-Nav. That way maybe you can just throw in a dvd player to replace the factory cd and get the screens for the headrest!
the folks at Lextasy has a similar product wshich is plug and play .. meaning it will plug directrly into you factory harness of the nav ecu.. without splicing.. it also comes with a built in tv tuner .. check out the threads..
http://www.lextasy.com/forum/viewtopic.php...81a78d3fc3c982a
Thanks silkoccy :cheers: !!! That is awesome....I will call Lextasy for more info!!!
