rugby4u21 Posted June 14, 2003 Share Posted June 14, 2003 Hello, I am new to this. I just bought a 1993 Lexus SC400 and i love it to death. I just have one question, i am going to gut the intake system and put a free flowing intake for it. I need to take off that little plastic piece that is near the bottom of the left headlight. I just need some tips on how to take off the headlight assembly. Please get back with me if you can. Thank you very much Mike 93' SC400 Quote Link to comment Share on other sites More sharing options...
eXo Posted June 14, 2003 Share Posted June 14, 2003 (edited) heya, if your looking at removing your induction that goes under your headlight then you'll have to remove your headlight also. Apart from the bolts/nuts you visually see from the top view there are also another two hidden inside the wheel arch. I'll try to explain this the best I can. Either take your wheel off or turn it full lock in. unscrew the plastic inside the wheel arch exposing the insides of the front section of your side panels. You'll then notice two bolts next to the indicator which you undo then the light will simply popout. To take the headlight itself apart you'll ahve to melt the glue. Just throw it in the oven for a few minutes but not too long as you don't want to melt your entire assembly. When the glue is soft enough you'll be able to pry the lens off, there are 3 sections the lens, the chrome bit inside and the rear backing. To reassemble, do the reverse. Edited June 14, 2003 by eXo Quote Link to comment Share on other sites More sharing options...
KY3TS Posted June 14, 2003 Share Posted June 14, 2003 CHECK OUT WWW.LEXUSGRILL.COM FOR DIY ON INTAKE REPLACEMENT AD HEADLIGHT REMOVAL. Quote Link to comment Share on other sites More sharing options...
rugby4u21 Posted June 14, 2003 Author Share Posted June 14, 2003 THANK YOU VERY MUCH!!! I REALLY APPRECIATE IT!! I will let you know how this "surgery" goes. If I have anymore problems i will post them. Again Thanks a bunch Mike 93' SC400 Quote Link to comment Share on other sites More sharing options...
mase Posted June 26, 2004 Share Posted June 26, 2004 lexusgrill is gone.. does anyone have a copy of the DIY? Quote Link to comment Share on other sites More sharing options...
