Lexus_Racer Posted December 31, 2004 Posted December 31, 2004 -hello- I just bought my car and i was just wondering, is the 1998 GS400 a front wheel or a rear wheel drive? Also, when i bought it, it has this one weird problem, both of the fan in the engine never stops running, both of the fan would always be running, what's wrong with it and what should i do?
Stapleford Posted February 25, 2009 Posted February 25, 2009 Regarding front wheel drive verses rear wheel drive, get in the car, step on the accelerator and you should know immediately which one you have. Those darn Lexus people, they never tell you, Id check the manual. If you need advise on riding a motorcycle during the winter, let me know on "how to". Regarding the fan issue, I too have it. It happened once and has not happened since. The fan continued to run for 30 min after the engine turned off. Heard a internal humming sound inside the car that would not stop,, first time it ever happened since buying the car new. I might have it checked out unless someone on this forum can direct me.
sakataj Posted February 26, 2009 Posted February 26, 2009 Regarding front wheel drive verses rear wheel drive, get in the car, step on the accelerator and you should know immediately which one you have. Those darn Lexus people, they never tell you, Id check the manual. If you need advise on riding a motorcycle during the winter, let me know on "how to". Regarding the fan issue, I too have it. It happened once and has not happened since. The fan continued to run for 30 min after the engine turned off. Heard a internal humming sound inside the car that would not stop,, first time it ever happened since buying the car new. I might have it checked out unless someone on this forum can direct me. if u cant sort out the sarcasm ALL gs's until 2006 were RWD (they r now available in certain trims in AWD) bad fan switch? stuck thermostat? check your basics first guys.....
