Memory Seats
Bluesoarer
I have a 92 sc400 and my memory seats don't work. I don't know if the buttons are bad or if its something else. The electronic seats work fine and the buttons are plugged in behind the panel. Does anyone know if this is a common problem for sc and if it is what is the first thing I should troubleshoot? Thanks
not a big problem. most likely its either a blown fuse or relay. check the fuse, worry about the relay after you know its not the fuse.
