Bluesoarer Posted December 29, 2004 Share Posted December 29, 2004 I have a 92 sc400 and my memory seats don't work. I don't know if the buttons are bad or if its something else. The electronic seats work fine and the buttons are plugged in behind the panel. Does anyone know if this is a common problem for sc and if it is what is the first thing I should troubleshoot? Thanks Quote Link to comment Share on other sites More sharing options...
BlackSC4 Posted December 29, 2004 Share Posted December 29, 2004 I have a 92 sc400 and my memory seats don't work. I don't know if the buttons are bad or if its something else. The electronic seats work fine and the buttons are plugged in behind the panel. Does anyone know if this is a common problem for sc and if it is what is the first thing I should troubleshoot? Thanks ← not a big problem. most likely its either a blown fuse or relay. check the fuse, worry about the relay after you know its not the fuse. Quote Link to comment Share on other sites More sharing options...
