mlm66 Posted December 24, 2004 Share Posted December 24, 2004 Yesterday my navigation screen had lines at the top and bottom, but no navigation map, it then went out after I pushed the map button. The audio bar comes up when you turn the radio on but has traff, flashing at the top, it then times out and the screen is blank again. My question, is there a reboot to the navigation system other then turning the ignition off & on, or do I have bigger problems with the unit? I have had the dvd bypass on for quite some time now and it never caused a problem. Thanks. Quote Link to comment Share on other sites More sharing options...
mlm66 Posted January 2, 2005 Author Share Posted January 2, 2005 Thanks for all the help. I really got alot of good advice. Helped me decide not to become a Gold member! Thanks again:-) Quote Link to comment Share on other sites More sharing options...
greggebhardt Posted January 8, 2005 Share Posted January 8, 2005 Yesterday my navigation screen had lines at the top and bottom, but no navigation map, it then went out after I pushed the map button. The audio bar comes up when you turn the radio on but has traff, flashing at the top, it then times out and the screen is blank again. My question, is there a reboot to the navigation system other then turning the ignition off & on, or do I have bigger problems with the unit? I have had the dvd bypass on for quite some time now and it never caused a problem. Thanks. ← Is your vehical not still under warranty? It should be, so take to them to fix it! :o Quote Link to comment Share on other sites More sharing options...
TCCRUISER Posted January 16, 2005 Share Posted January 16, 2005 Disconnect battery. Reconnect battery. Start engine. Watch Nav system reboot! Quote Link to comment Share on other sites More sharing options...
