rswint Posted June 10, 2003 Posted June 10, 2003 I just purchased a transmitter set (key and small control module) for 1990 LS400. Dealer said install was easy; just remove left panel in trunk and replace module. I find nothing in the left panel that remotely resembles the new control module. New module is aprox. 1"x 1"with small 6 pin female reciever connector on it aprox 3/4"w x 3/8"h. Where does this thing go? I just got the LS and have not purchased the repair manual yet. I have a high speed connection so I could accept a scanned page of the instructionswithout a problem HELP!
SKperformance Posted June 10, 2003 Posted June 10, 2003 shoould be a small balck box under the carpet remove the module and undo a screw holding a flap on to it inside you will see the old eprom to swtich just wondering what is the code written on the old key
