PimpedRX Posted November 30, 2004 Share Posted November 30, 2004 Hey... I need help... I have asked around and nobody can tell me the answer im looking for. I just turned sixteen and got a 99 rx300. I also have a set of 20 inch momo magnum rims which were given to me. Will they fit my car. If not is there any way i can get them to fit. Thanks alot Quote Link to comment Share on other sites More sharing options...
bartkat Posted November 30, 2004 Share Posted November 30, 2004 Hey... I need help... I have asked around and nobody can tell me the answer im looking for. I just turned sixteen and got a 99 rx300. I also have a set of 20 inch momo magnum rims which were given to me. Will they fit my car. If not is there any way i can get them to fit. Thanks alot ← Go to http://www.tirerack.com/ and find out what fits your car. Then find out what the Momo's are. Quote Link to comment Share on other sites More sharing options...
PimpedRX Posted November 30, 2004 Author Share Posted November 30, 2004 Hey... I need help... I have asked around and nobody can tell me the answer im looking for. I just turned sixteen and got a 99 rx300. I also have a set of 20 inch momo magnum rims which were given to me. Will they fit my car. If not is there any way i can get them to fit. Thanks alot ← Go to http://www.tirerack.com/ and find out what fits your car. Then find out what the Momo's are. ← I dont see anything on momo magnums... it only gives me 7 rims to choose from and they are only 18 inch tops... can someone do a little more research for me please. Quote Link to comment Share on other sites More sharing options...
strmrdr23 Posted December 2, 2004 Share Posted December 2, 2004 you're gonna need to figure out what offset they are...i don't think there's a real easy way to figure that out unless they told you what offset the are, tho...you should just take off one wheel in back and just see if they fit on there...i got some 20's on my rx and they sit on 245/40/20 tires...i don't remember what my offset was in back (+32 mebbe)...hope that helps... Hey... I need help... I have asked around and nobody can tell me the answer im looking for. I just turned sixteen and got a 99 rx300. I also have a set of 20 inch momo magnum rims which were given to me. Will they fit my car. If not is there any way i can get them to fit. Thanks alot ← Go to http://www.tirerack.com/ and find out what fits your car. Then find out what the Momo's are. ← I dont see anything on momo magnums... it only gives me 7 rims to choose from and they are only 18 inch tops... can someone do a little more research for me please. ← Quote Link to comment Share on other sites More sharing options...
TunedRX300 Posted December 2, 2004 Share Posted December 2, 2004 Hey... I need help... I have asked around and nobody can tell me the answer im looking for. I just turned sixteen and got a 99 rx300. I also have a set of 20 inch momo magnum rims which were given to me. Will they fit my car. If not is there any way i can get them to fit. Thanks alot ← See if they have 5x114.3 bolt pattern, +35 offset, 6.5-7.5 inch width. I am not sure how much you can get away with a different offset. You need to adjust the tire size to go with bigger rims. Quote Link to comment Share on other sites More sharing options...
PimpedRX Posted December 3, 2004 Author Share Posted December 3, 2004 Hey... I need help... I have asked around and nobody can tell me the answer im looking for. I just turned sixteen and got a 99 rx300. I also have a set of 20 inch momo magnum rims which were given to me. Will they fit my car. If not is there any way i can get them to fit. Thanks alot ← See if they have 5x114.3 bolt pattern, +35 offset, 6.5-7.5 inch width. I am not sure how much you can get away with a different offset. You need to adjust the tire size to go with bigger rims. ← But they will defintley fit though correct, i just need to make some adjustments? Quote Link to comment Share on other sites More sharing options...
strmrdr23 Posted December 3, 2004 Share Posted December 3, 2004 you might need spacers if they're the wrong offset...i'm not a big fan of using spacers, tho... Quote Link to comment Share on other sites More sharing options...
TunedRX300 Posted December 3, 2004 Share Posted December 3, 2004 Needs to be careful because you don't want wheels to rub against spring/shock support. Find out your offset first. wwest has 8 inch rims and spacers in the rear. You may want to PM him. Quote Link to comment Share on other sites More sharing options...
