235/70 R16 Vs 225/70 R16
jlane
I'm looking for replacement tires for our RX300. I have locate what appears to be a reasonable replacement - Bridgestone AT/REVA's. The issue is that they are made in 235/70 vs 225/70(LEXUS recommended). There in 10 mm difference in width, approximately 14mm difference in diameter, and 44 mm in circumference. Has anybody made this change, what are the effects and/or pitfalls?
Thanks
If the stock tire is 225/70 replaced with 235/70:
Speedometer reading will be 1.9% too slow
With speedometer reading 60 mph, you're actually travelling 61.2 mph.
This does not include any built-in error factoring in the speedo from Lexus.
But you also get the benefit of odometer reading < actual distance traveled, which means less depreciation of car resell value and more warranty time.
255 75 R16 I love them and they fill the fender well perfect.
