Wrigley132 Posted June 6, 2003 Share Posted June 6, 2003 I just bought a used 1996 ES300 and can hear a somewhat annoying air leak above my head when the moon roof cover is pulled back. When I slide the cover closed, I really don't hear it much. So before someone says to just keep the cover closed, can a Lexus Service Tech, or anyone for that matter, effectively address this problem with a better seal?....Thanks... Quote Link to comment Share on other sites More sharing options...
SKperformance Posted June 6, 2003 Share Posted June 6, 2003 since i cnnot see the seal it is hard to say wether it is the seal or the roof needs to be adjusted in position with shims do you have a cell phone antenna? as this can sometimes cause excess noise also one option is to use silicone spray on the seal to help the seal .........seal also use the spray on all the windows and doors edges and don't forget the trunk as any air to get out has to get in first seal as many places as possible and you will reduce wind noise also the doors may be leaking on the windowsedges if they are closed frequently by passanger using the window instead of the door and since there is no frame it goes out of alignment and leaks air usually and not water Quote Link to comment Share on other sites More sharing options...
NeiLtYmE Posted June 6, 2003 Share Posted June 6, 2003 Whats a good kind of silicone spray... where can it be bought ? - neil Quote Link to comment Share on other sites More sharing options...
SKperformance Posted June 7, 2003 Share Posted June 7, 2003 any brand they all are pretty much the same pep boys and napa any real auto parts seller i don't think walmart but i haven't looked lately in the auto aisle in a U.S. stoer for silicone spray lol later Quote Link to comment Share on other sites More sharing options...
