2004 ES330 power steering
Texasgreg
I have a 2004 es330
Power steering pressure hose was leaking so I replaced it with an OEM part.
No more leaks!  However,
Now it is extremely difficult to turn in both directions.
Prior to the hose change out I had absolutely no problems steering. I could tun the wheels in both directions with ease, now it's like a tug a war with Mike Tyson.
Please help,
Greg
9 hours ago, Texasgreg said:
I have a 2004 es330
Please help,
Greg
Quote
CoPilot:
Here are a few things to check:
  1. Power Steering Fluid Level: Ensure the fluid is at the correct level. Low fluid can cause steering issues.
  2. Belt Tension: Check the tension of the serpentine belt, as it drives the power steering pump.
  3. Air in the System: Sometimes, air can get into the power steering system during repairs, causing difficulty in steering. You might need to bleed the system to remove any trapped air.
  4. Steering Rack: Ensure that the steering rack and its connections are secure and not damaged.
