Fred Kerrick Posted 3 hours ago Share Posted 3 hours ago Service provider informed me I had a front timing cover leak. Any thoughts? Quote Link to comment Share on other sites More sharing options...
RX400h Posted 26 minutes ago Share Posted 26 minutes ago 3 hours ago, Fred Kerrick said: Service provider informed me I had a front timing cover leak. Any thoughts? Quote Copilot Sent by Copilot: A front timing cover leak in your 2012 Lexus RX350 is a known issue for some Toyota and Lexus models. Here are a few key points to consider: Common Issue: This problem often arises due to a blown gasket or sealant failure. It’s not uncommon for these leaks to develop over time. Repair Complexity: Fixing a timing cover leak can be quite labor-intensive. It typically involves removing significant parts of the engine, which can make it a costly repair. Estimates suggest it could take anywhere from 16 to 22 hours of labor. Cost: The cost of this repair can vary widely. Some owners report quotes around $2,500, but it can be less depending on the mechanic and location. Severity: While the leak might start small, it’s important to monitor it. If left unchecked, it could lead to more significant issues, such as oil loss and potential engine damage. DIY Fixes: Some minor leaks might be managed temporarily with products like BlueDevil Oil Stop Leak, which can restore the gasket. However, this is usually a short-term solution. Given the complexity and potential cost, it might be worth getting a second opinion Quote Link to comment Share on other sites More sharing options...
