flash back: my ls400 is 94K miles, just finished changing timing belt kit, changed catalytic converters, just did a tune up, which the lazy tech. just change 8 spark plug, nothing else.
Then I took it to the emission test again, and it faile again.
I changed the catalytic converters. Most of you guys were right. My cat. converters were bad. I changed those and it fixed the NOx.
the problem i have now is the HC, CO rise real high and the NOx dropped real low.
what is the problem? what should I do to fix this? :unsure:
thanks
You only changed the spark plugs and nothing else at all for the tune-up? Can you scan your test results again so I could see them? How does your car run after the timing belt change? Does it idle rough? Has the air filter been replaced?
  • 3 years later...
