terkmobbin Posted August 27 Share Posted August 27 Hi All, I am wondering if anyone knows the serpentine belt size that I should use if I plan to delete my A/C compressor. Quote Link to comment Share on other sites More sharing options...
RX400h Posted August 27 Share Posted August 27 2 hours ago, terkmobbin said: Hi All, I am wondering if anyone knows the serpentine belt size that I should use if I plan to delete my A/C compressor. Quote If you’re planning to delete the A/C compressor on your 2000 Lexus LS400, you’ll need a shorter serpentine belt. Based on information from various sources, a common recommendation is to use a 6PK1585 or 6PK1590 belt. Some users have also found success with a 6PK1600 belt. It’s always a good idea to double-check the belt routing and tension to ensure proper fit and function. If you have any other modifications, such as changes to the fan setup, the belt size might vary slightly. Source: CoPilot AI Quote Link to comment Share on other sites More sharing options...
