Michael kerr Posted August 24 Posted August 24 Recently bought a gx470 2004 with 191000 miles was a one owner and all maintenance has been keep up with and done by Lexus or toyota dealerships , the timing belt was replaced at 107000 the rear airbags were replaced at 160000,, oil has always been changed on time it’s whole life southern car frame is perfect no rust,was keep in garage no peeling paint,the car runs and drives good except the transmission will shift hard not all the time noticed before I bought it it had transmission oil in coolant in the overflow tank smod or strawberr Milkshake,I I got the car for 4300 and I have already ordered parts to replace the radiator with a welded aluminum one,replace timing belt,hoses water pump ,and have the coolant system flushed along with the transmission ,will the transmission survive or did I make a mistake
RX400h Posted August 24 Posted August 24 13 hours ago, Michael kerr said: Recently bought a gx470 2004 with 191000 miles was a one owner and all maintenance has been keep up with and done by Lexus or toyota dealerships , the timing belt was replaced at 107000 the rear airbags were replaced at 160000,, oil has always been changed on time it’s whole life southern car frame is perfect no rust,was keep in garage no peeling paint,the car runs and drives good except the transmission will shift hard not all the time noticed before I bought it it had transmission oil in coolant in the overflow tank smod or strawberr Milkshake,I I got the car for 4300 and I have already ordered parts to replace the radiator with a welded aluminum one,replace timing belt,hoses water pump ,and have the coolant system flushed along with the transmission ,will the transmission survive or did I make a mistake Quote It sounds like you’ve got a well-maintained Lexus GX470 with a lot of life left in it! The “strawberry milkshake” issue you mentioned is a common problem when transmission fluid mixes with coolant, often due to a failed radiator. Replacing the radiator and flushing both the coolant and transmission systems are crucial steps to address this issue. Given that the transmission is shifting hard but not all the time, it’s possible that the contamination hasn’t caused severe damage yet. However, it’s important to monitor the transmission closely after the repairs. Here are a few things to consider: Transmission Fluid: Ensure the transmission fluid is clean and at the correct level. Contaminated fluid can cause shifting issues. Transmission Filter: Replace the transmission filter if it hasn’t been done recently. Professional Inspection: Have a transmission specialist inspect the transmission for any signs of damage or wear. The A750F transmission in the GX470 is generally reliable, with a lifespan of around 250,000-280,000 miles if well-maintained. Since your vehicle has been well cared for, there’s a good chance the transmission will survive, especially with the preventive measures you’re taking. Keep an eye on the transmission’s performance after the repairs. If you notice persistent issues, it might be worth having a professional diagnose it further. Overall, it sounds like you got a good deal on a solid vehicle!
Quadragin Posted 3 hours ago Posted 3 hours ago Coolant will destroy transmission clutch packs in little time, hopefully you got lucky.
