David the Red Posted July 16 Share Posted July 16 (edited) I have a rear seat that would not come up from down flat up to sitting position. I was told by my mechanic that a replacement release cable was not available. It is a 2004 RX330. Does anyone know a substitute that would work, or a way to improvise a solution? Edited July 16 by David the Red left out part description Quote Link to comment Share on other sites More sharing options...
RX400h Posted July 16 Share Posted July 16 7 hours ago, David the Red said: I have a rear seat that would not come up from down flat up to sitting position. I was told by my mechanic that a replacement release cable was not available. It is a 2004 RX330. Does anyone know a substitute that would work, or a way to improvise a solution? Quote While finding an exact replacement release cable might be challenging, there are a few potential solutions you can explore: Check for Availability: Although your mechanic mentioned that a replacement cable isn’t available, it’s worth checking with Lexus dealerships or authorized parts suppliers. Sometimes, they may have access to discontinued or rare parts. You can also search online platforms that specialize in used or salvaged car parts. Sometimes, you might find a compatible cable from a scrapped vehicle. Improvise a Solution: If a direct replacement isn’t feasible, consider improvising a solution. Here are a few ideas: DIY Repair: Inspect the existing cable carefully. If it’s damaged at a specific point, you might be able to repair it using basic tools and materials. Adapt a Different Cable: Look for a similar cable (even if not specifically designed for your RX330) that has a similar length, flexibility, and strength. You can modify it to fit your seat release mechanism. Custom Fabrication: Consult an automotive specialist or fabricator who can create a custom cable based on the original design. They might be able to replicate the functionality. Explore Other Components: Sometimes, the issue isn’t solely with the cable. Check related components like the seat latch release handle or the seat track stop plate. A malfunction in these parts could also prevent the seat from moving properly. Remember to prioritize safety and consult a professional if you’re unsure about any modifications. Good luck with resolving the seat issue! 1 Quote Link to comment Share on other sites More sharing options...
